Shiva3758
Aug 07, 2022Tutor
NIGHTHAWK AX6 AX4300 - Update error
I continue to get an Update Error when I try to update the router. Any suggestions on how to remedy? MODEL: AX6 AX4300 MAC IOS 15.16 HARDWARE VERSION. RAX45 FIRMWARE V1.0.11...
- Aug 07, 2022
Thanks for your help. Despite the prompts to update the firmware on the IoS mobile app, the firmware appears to be the latest available version. Appreciate everyone's input.
michaelkenward
Aug 07, 2022Guru - Experienced User
plemans wrote:
What actual version are you on?
FIRMWARE V1.0.11.112
That seems to be the latest version:
RAX45 Firmware Version 1.0.11.112 | Answer | NETGEAR Support
Not sure what the problem is!
Shiva3758
Aug 07, 2022Tutor
- michaelkenwardAug 07, 2022Guru - Experienced User
Makes a change. The usual problem is that apps say "firmware up to date" when there is a fresher version available.
