woodland
Sep 12, 2024Aspirant
Nighthawk AX6 AX4300 as a WIFI extender for Bell Giga Hub
Internet Provider / Equipment: Provider: Bell Installation Type: Fiber Provider Equipment = Sagemcom Giga Hub 5689E My Equipment: Nighthawk AX6 AX4300 6-Stream WIFI Router Configuratio...
Sep 12, 2024Guru - Experienced User
What RAX### model number is this router?
Try AP mode on the RAX series router:
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
- woodlandSep 12, 2024Aspirant
The Router is classified as an RX45
- michaelkenwardSep 12, 2024Guru - Experienced User
That would be the RAX45, which you tagged in your first message.
You can use the RAX45 as an access point.
How do I change my NETGEAR router to AP mode? | Answer | NETGEAR Support
That does lose some of the functions on the RAX:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
But your main router should handle those things.
If you have Ethernet throughout the place, try the RAX in various places to see which gives you the best coverage. Somewhere between the main router and most remote bit of the property is probably best. But if the area really is big, your two sources may not be powerful enough to flood the place with WiFi.
Just another user with time on their hands.
- woodlandSep 16, 2024Aspirant
Thanks for the information and links
I reconfigured my device as an access point. When I connect to the Bell App I can see that the NightHawk is connected with an IP of 192.168.2.43
Is there anyway for me to determine if the Access point is working. In other words is there a way I can tell if any wireless devices are using the access point or connecting via a different further way Access point.
When I look at the network using the Bell app, I only see the Gigahub and one pod. I am assuming the app only has the ability to show bell connected devices.
Thanks Again
