tolanda
Oct 15, 2022Tutor
Nighthawk AX6 AX4300: external HD connected to Readyshare USB keeps disconnecting, won't reconnect
I have a Nighthawk AX6 AX4300 6-Stream WiFi router (RAX45) with a USB port. I have connected an external hard drive to the USB port so I can access media content through the WiFi. When the router i...
iyang
Oct 24, 2022NETGEAR Expert
- tolandaNov 13, 2022Tutor
Hi,
Sorry for the late response. The Nighthawk firmware version is "V1.0.11.112 and the external hard drive is a 500MB Seagate Free Agent, 9NK2AG-500
- tolandaFeb 08, 2023Tutor
Hi,
Any suggestions a resolution to this issue? Is there a limitation on my nighthawk model where it has the hard drive go to sleep after a certain period and is unable to wake it up or is the hard drive I'm using not compatible with the router?
Any help is appreciated.
Thanks,
Dave
