tolanda
Feb 12, 2023Tutor
Nighthawk AX6 AX4300: external HD connected to Readyshare USB keeps disconnecting, won't reconnect
Hi, I have a Nighthawk AX6 AX4300 6-Stream WiFi router (RAX45) with a USB port. I have connected an external hard drive to the USB port so I can access media content through the WiFi. When the ...
tolanda
Feb 15, 2023Tutor
Sorry, it's also self powered using an AC plug. It doesn't need to get its power from the PC or router.
Feb 15, 2023Guru - Experienced User
what format is it in?
- tolandaFeb 21, 2023Tutor
The format is exFAT.
- plemansFeb 21, 2023Guru - Experienced User
You might try an appropriate format for it.
What are the USB drive requirements for ReadySHARE on my NETGEAR router? | Answer | NETGEAR Support
- tolandaFeb 22, 2023Tutor
Thanks for the information. I will connect a hard drive with one of the supported formats and see if that works.
