tolanda
Feb 12, 2023Tutor
Nighthawk AX6 AX4300: external HD connected to Readyshare USB keeps disconnecting, won't reconnect
Hi, I have a Nighthawk AX6 AX4300 6-Stream WiFi router (RAX45) with a USB port. I have connected an external hard drive to the USB port so I can access media content through the WiFi. When the ...
Feb 21, 2023Guru - Experienced User
You might try an appropriate format for it.
What are the USB drive requirements for ReadySHARE on my NETGEAR router? | Answer | NETGEAR Support
tolanda
Feb 22, 2023Tutor
Thanks for the information. I will connect a hard drive with one of the supported formats and see if that works.
