javidelgadillo
Apr 28, 2021Tutor
Nighthawk AX6 AX4300 RAX45 Youtube Restricted Mode
After purchasing the Nighthawk AX6 AX4300 RAX45 router, I enabled Parental Controls. It was very restrictive to the point of blocking several sites that my kids needed for school. I wound up setting them all to Adult Profile, but even then the router seems to be enabling YouTube Restricted mode without the ability to disable in the browser. Is there some setting in the mobile app or admin page I can use to disable the enabling of Youtube Restricted mode?
-Javier
1 Reply
Sort By
- Christian_RNETGEAR Employee Retired
Hello Javier,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
