scotmicharm
Jan 13, 2021Follower
Nighthawk AX6 AX5400 and existing bulk cat6a not working
Just upgraded from Nighthawk R7000 where existing bulk cat6a cable in the home works. The new Nighthawk AX6 AX5400 is not working with this existing cat6a cable. I tried some retail cat6a cable with t...
Jan 14, 2021Guru - Experienced User
You kind of already did the diagnosis.
You found one set of cable run didn't work but replacing it with a new/premade did work.
Kind of points at the cable. You can try replacing the ends on the cable to see if there's a bad pair or miswiring going on.
