Jeffpatton00
Nov 13, 2022Aspirant
Nighthawk AX6 AX5400 country of origin
None of the marketing info seems to list the country of origin for this model. Does anyone know where it's manufactured? thx
Jeffpatton00
I would prefer not to purchase a router made in China, so I'm hoping to determine the country or origin before I purchase the item. Netgear, do you have anyone following this forum? Can you tell me where it's made?
Jeff
Nov 13, 2022Guru - Experienced User
Might contact NG support to see.
I see my RAX50 is made in Vietnam.
Some other models may come from Taiwan. Maybe Philipenes...?
- michaelkenwardNov 14, 2022Guru - Experienced User
Vietnam is certainly a regular source, but one model made there might also end up being made somewhere else.
So the most reliable solution may be to go to a store and look at the label.
