LydiaRossi's avatar
LydiaRossi
Follower
Nov 30, 2020
Nighthawk AX6 does not connect to my cannon printer
1 Reply
  • plemans's avatar
    Which router do you have? AX6 isn't a model number.
    What firmware is on it?
    What cannon printer are you trying to connect?
    Also, its the printer that has to connect to the router, not the router connecting to the printer.
    Have you checked with cannon on setup process for your printer?
