Ron23
Dec 02, 2021Tutor
Nighthawk AX6-RAX45 latest firmware
I have a Nighthawk Nighthawk AX6-RAX45. The current version in my router is: V1.0.2.82_2.0.50 It seems there are newer versions of the firmware out there but when I go to the Router Update option an...
Dec 02, 2021Guru - Experienced User
It seems there are newer versions of the firmware out there but when I go to the Router Update option and select "Check" it tells me "No new firmware version available."
So I have 2 questions:
1. What is the latest firmware version for this router? Check here for whats most current:
https://www.netgear.com/support/
Input your router model #.
2. Why the built in option to update doesn't find newer versions of the firmware?
Some times NGs web site gets updated before the auto update servers. So they may not be on the same page.
You can always manual update FW as well:
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6
Thank you.
