Believe35
Aug 01, 2021Follower
Nighthawk AX6 RAX45 settings lost
Woke up yesterday and all settings lost. Restarted, reset to factory then reset still only showing BERNIE Rax50 as available networks. Now what??
Rachon
Aug 13, 2021Initiate
Did you fix it? I'm having the same problem.
DarrenM
Nov 16, 2021Sr. NETGEAR Moderator
If you are seeing the issue with the wifi name changing to bernie please PM me I have a test firmware that has a fix.
Thanks
DarrenM
- KhaibuiDec 04, 2021AspirantI have the same problem yesterday. Please help!
- DarrenMDec 06, 2021Sr. NETGEAR Moderator
The latest firmware should resolve the bernie issue.
DarrenM
- tekzer0May 01, 2022Aspirant
I dont have the bernie issue, but i have a rax75 and like all other nighthawk routers ive owned, the settings randomly disappear and wont even reappear after factory reset & reloading saved settings. and i can even flash newest firmware again and set the settings, and sometimes it shows the enabled settings, sometimes it shows default regardless of whats enabled or set and sometimes like with port forwarding, it wont show any of the settings i have set to be able to modify or delete and the GUI via browser (regardless of browser) is buggy like that always. Every nighthawk routers gui is the worst! settings even randomly actually change (and not just saying the setting is different when it isnt). Ive had this $500 POS for a year now dealing with this crap... and when i bought it off amazon from your store, it wouldnt even let me activate armor out of the box! several tickets and it was never solved either. since i flipped out on the person replying for a second nighthawk device being garbage that id purchased and had the same exact flaws totaling over $1000 wasted and only excuses from Netgear, on this day I officially give up on all netgear garbage since they always have no answer the the same problems!
