beach2916
May 13, 2021Follower
nighthawk ax6 rax50
My app device manager setting is really parental control? it shows my devices(16)? but It's working properly? how do I fix the app?
michaelkenward
May 14, 2021Guru - Experienced User
I don't understand the question.
What does that mean?
Which app.
I see no suggestion that the rax50 supports parental controls. The Nighthawk app does not support the free version.
In any case, it is dead. The only option now is to pay for Circle. I don't think the rax50 supports that either.
Which NETGEAR routers support Circle Smart Parental Controls? | Answer | NETGEAR Support
Which app?
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You may have done this already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals years ago and people sometimes miss the downloads.
