Jul 29, 2020Follower
Nighthawk AX6
How do I personalize my network name?
There's an article on it.
https://kb.netgear.com/23439/How-do-I-change-my-NETGEAR-router-s-WiFi-password-or-network-name-SSID
or you can look it up in your manual.
go to netgear.com/support/ type in your actual model number and it'll take you to the manual, firmware, install guides, etc.
- AlexTucsonAspirant
Just installed the Nighhawk AX6 Router. Wasn't an easy installation. Kept telling me I wasn't on the SSID I was on.
Resolved that. App installed.
But App won't run a speed test. All zeros.
Suggestions??
- CallPaulApprentice
The speed test in the app takes a long time to work, usually around 30 seconds or so.
its pretty accurate but very slow.
