gaschadler
Dec 06, 2020Follower
Nighthawk AX6
Nighthawk AX6 - AX5200 WiFi Router Trying to set up ReadySHARE USB Printer Utility 3.1 for Mac. (Running most current version of MacOS) Get error when trying to install. Did not complete install. ...
michaelkenward
Dec 07, 2020Guru - Experienced User
You have posted your message in the section of this community given over to Cable Modems, Routers and DSL Modems. (This is easily done, given Netgear's impenetrable community structure.)
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
I will ask the Netgear moderator to move your message.
