RenatoBraga
Jul 24, 2019Aspirant
NIGHTHAWK AX6000 NOT CONNECTING TO INTERNET
My access to internet is provided by a cable moden ARRIS. I followed all the instruction to connect the Nighthawk to the internet (though one of the ports of the Arris cable moden). Nevertheless, the...
lantrick
Jul 24, 2019Tutor
You have too little information to know for certain , but you can try these steps.
1. You would need to power cycle the ARRIS after switching devices connected to it. If the ARRIS is an MTA (telephone and internet) it has a back up battery inside and you will need to stick a paper clip into the small into the hole on the back that says "reset" and press the switch inside. Unpluging it won't turn it off if it has a back up battery.
2. Connect you computer directly t the Arris and see it the intemet works. If not , get this working first. Then try the router again.
If after you have powercycles everything, and verified that the Arris can connet to the internet. Call Netgear phone support.
