Uncleenyaw's avatar
Uncleenyaw
Nighthawk Ax6000 RAX120
When I reboot my RAX120 router it causes me to lose my internet connection. I have to manually reboot my cable modem (Motorola Surfboard) to get the internet to work again. I have to turn off/on the wireless connection on the router to get the internet working again. This problem is happening frequently and not sure whether it’s the router causing the issue or the cable modem (several years old). What can I check to rule out that the issue is unrelated to the RAX120?
  • plemans's avatar
    couple questions.
    1. What modem are you using?
    2. What firmware is on the router?
    3. Why are you rebooting the router?
    4. When you lose your connection, is it disconnecting from wireless or is it just saying "no internet available"?
    5. How frequently is it happening?
    • Uncleenyaw's avatar
      Uncleenyaw
      RAX120
      couple questions.
      Motorola SB8120
      1.0.0.84 (note router said that there were no firmware updates available)
      To fix internet issues with home PCs and devices. Some are wired and some are wireless. Happens in both types of connections.
      Can’t connect To the internet from wired/wireless devices. The Nighthawk App shows internet offline and the dashboard shows a not connected message.
      It’s happened 4 times in the last 24 hours. Before that I don’t recall it happening much. I just bought the router in early October.
      • plemans's avatar
        Based off you're responses, we need to determine if it is indeed a router problem or if its a modem issue. Whenever you get both dropping (wired/wireless) you have to figure out exactly which one is causing it.
        Do you have a screen snip of your modem connections page? And logs?
        If you're directly wired into the modem and run it for while, does the issue still happen?
        There is a newer firmware for the router but its a fix for a wireless connection issues.
        If you recently updated the firmware, have you tried a factory reset? the newer RAX devices have responded favorably to factory resetting after firmware updates.
  • There is .100 fw for the rax120. I think it might help with this issue.
