Satchmo's avatar
Satchmo
Follower
Aug 03, 2020
Nighthawk AX6000 WiFi Cable Modem Router
What current Netgear Extenders are most compatible with the new Nighthawk AX6000 WiFi Cable Modem Router, ZModel Number CAX80?
1 Reply
  • plemans's avatar
    "most compatible"? All of netgears will work.
    I'd recommend the triband extenders over even the current AX extenders. Reason why is a standard dual band extender has to send and receive using the same chip. And they can't do both at once. So they cut throughput 50%. The tribands get around this by having a 2nd 5ghz chip just for router----extender communication. Tends to make them faster and more stable.
