Richtheclich's avatar
Richtheclich
Follower
Dec 06, 2023
Nighthawk ax6600
Having a lot of issues with this Netgear router and modem setup. The AX6600 keeps on disconnecting randomly. The speed drops out of no where. Running 800mbps download 51 upload. And tomorrow comes and...
  • microchip8's avatar
    Dec 06, 2023
    Which router model do you have? AX6600 is a speed, not model! Look at the label.
    Tried a factory reset and config from scratch?
