t-hayes
Feb 17, 2019Aspirant
Nighthawk AX8 - RAX80-100NAS - IP lease time can't be set?
Since putting in the new router I've had several problems with connections being dropped for a few seconds and couldn't understand why. It wasn't all at once and wasn't occurring that frequently. ...
myersw
Feb 18, 2019Master
I hard coded the IP address in my 2 NAS so as to not fight any of these problems. Be sure to pick an IP outside of the DHCP address scope. Never have had a failure since.
t-hayes
Feb 19, 2019Aspirant
I decided to just send it back and buy something else. For $400 I can't see having disconect issues all the time and the number of other little weird internet issues that have been more and more numerous. For that kind money I expect things to work.
- myerswFeb 19, 2019Master
Things will probably work better if the replacement router does not have the name Netgear on it.
- OffyMar 18, 2019Aspirant
Did you try using the DHCP reservation feature in the router?
Advanced >> Setup >> LAN Setup
Scroll to the bottom and add an IP reservation for the MAC address of the device.
I do not understand why someone would attempt to direct you to telnet into your device when the setting is readily available in the GUI.
