jay_murillo's avatar
jay_murillo
Nighthawk AX8 2.4GHz Speed/ Distance problem?
Hello
Hoping you guys can help me out ..
Just purchased my Router and was super excited since ive been using the Spectrum rental which has been giving less than adiquate speeds..
Im currently on 200 Mbps.
The Router is Awesome when it comes to the 5GHz band.. I can go all the way to my Bedroom (50ft-60ft) and its giving me 234Mbps down and 10Mbps up. WOW! Amazing!!!
Its when I switch to the 2.4 that it takes a HUGE dive! Im doing speeds of 3-5Mbps down and .90 to 1Mbps up in the bedroom....
Horrible! Ive have tried everything and have even uploaded the current
Firmware VersionV1.0.2.76_1.0.35
I was running FirwareV1.0.2.70 when i first turned on and it was doing a little better, but not much difference! Now its just rediculous! kinda bummed out!..
I mean even in front of the router 3-5ft im getting 30-45Mbps Tops!? Is this normal???
What Gives??
Any Ideas??
Thanks
Jay
  • What is the client you running tha has the slow speed? AC or AX or N ?
    Turning off MU-MIMO helped mine
    • jay_murillo's avatar
      jay_murillo
      i believe it’s Ac
      It’s 3x iphones that i’ve checked with and also my new Lenovo laptop
      Disappointed in this router
