Lulumadd
Jan 03, 2020Aspirant
Nighthawk AX8 AX6000 (RAX75) does not connect to Routerlogin.net
Set up my Nighthawk AX8 AX6000 WiFi Router(RAX75) today. I could not stay connected to routerlogin.net after it asked me to change the password (safari couldn't reach server - same error msg when ty...
Jan 03, 2020Guru - Experienced User
1. What modem are you using? (model #)
2. Firmware on your RAX?
3. have you tried a different browser or pc?
Lulumadd
**RAX75 - 100NAS
**it was updated upon installation to: V1.0.1.70_1.030
****Hmmm we only have Macs & apple products but I just tried Google Chrome & was able to log in on another laptop. Thanks for the suggestion but....
What's up with that??
Is this router not compatible with Safari and IOS?
- plemansJan 03, 2020Guru - Experienced User
Lulumadd wrote:1. What modem are you using? (model #)
**RAX75 - 100NAS------This is the router model. not the modem. We ask modem model because some people are running modem/router combo devices connected which can cause many issues. Similar to what you're experiencing.
Is this router not compatible with Safari and IOS?------it is but sometimes the browsers have data retained in their cache or other issues. Even chrome had a version with issues. Which is why if a device is having issues, its worth trying a different browser, pc, or even just clearing out your browser settings. its a simple first step.
- LulumaddJan 03, 2020Aspirant
*** whoop sorry. its a Ubee modem DVW32C1
supplied by TWC/Spectrum
**so just a CLEAR HISTORY in Safari? or something more involved?
Thank you so much for your help so far!
You're problem is likely the Ubee DVW32C1.
Its a combo device which means it incorporates a modem and router together into a combo device. Unless its in modem only mode, you're in a double nat.
https://kb.netgear.com/30186/What-is-Double-NAT
To fix a double nat the 2 easiest routes are to either place the ubee in modem only/pass through mode or to place the netgear in access point mode. Access point mode does disable some of the netgear's features because it leaves the ubee running in router mode.
If you want the ubee in modem only/passthrough mode, contact the isp as they'd be the experts on setting up their device.
