wardh_2021
Feb 20, 2023Follower
Nighthawk AX8 AX6600 - Port and cable troubleshooting
Hi, I have the following router: Nighthawk AX8 AX6600 Tri-band 8-Stream WiFi 6 Router (Nighthawk AX8 AX6600 WiFi 6 Router) Router Firmware Version V1.0.13.128 I am trying to solve an iss...
Feb 20, 2023Guru - Experienced User
how often does it happen?
When it happens, does your switch have LED's on it you can check the connection?
Do you have any long ethernet cables you could direct wire those device in to test it?
