Theplum
Aug 01, 2019Aspirant
Nighthawk AX8 Internet Speed Test
Hi All, After an update to V1.0.1.62_1.0.26 on my AX8 router, it is impossible to update the network speed through SpeedTest (I can run the test but the result will return to the previous one...
Theplum
Hi All,
I forget to mention that the SpeedTest is found under the QoS tab.
Tim
Christian_R
Aug 05, 2019NETGEAR Employee Retired
Hello Theplum - We recommend performing a factory reset after a firmware update. Please perform a factory reset and let us know if you're running into the same issue.
~Christian
