JeffLewis
Aug 29, 2020Aspirant
Nighthawk AX8 NTP settings not retained
I just received this router and while browing through the settings I noticed that the time and date were incorrect. After setting the correct time zone and applying changes it was still showing Inter...
Christian_R
Sep 04, 2020NETGEAR Employee Retired
Hi JeffLewis,
I have a trial firmware that may help resolve your issue. If you're interested, please send me a private message with your email address and serial number.
Christian
- JeffLewisSep 06, 2020Aspirant
Hello,
After upgrading firmware to V1.0.3.102_2.1.46.1, the current time is now correct but the router will still not accept changes to time zone and/or new NTP server settings.
Thanks!
- Christian_RSep 09, 2020NETGEAR Employee Retired
Hi JeffLewis,
May you perform a factory reset on the router after updating the firmware.
Christian
- paperbagOct 15, 2020Tutor
I have the same issue. The settings are default back to "International Date Line West". It won't let me set to "Pacific Time (US & Canada); Tijuana". In my screenshot, I am running as Access Point but this issue happened no matter what I set it to (primary router or access point). When I flashed back to v1.0.3.88, the issue goes away.
