JeffLewis
Aug 29, 2020Aspirant
Nighthawk AX8 NTP settings not retained
I just received this router and while browing through the settings I noticed that the time and date were incorrect. After setting the correct time zone and applying changes it was still showing Inter...
JeffLewis
Sep 06, 2020Aspirant
Hello,
After upgrading firmware to V1.0.3.102_2.1.46.1, the current time is now correct but the router will still not accept changes to time zone and/or new NTP server settings.
Thanks!
Christian_R
Sep 09, 2020NETGEAR Employee Retired
Hi JeffLewis,
May you perform a factory reset on the router after updating the firmware.
Christian
