SeanML's avatar
SeanML
Initiate
May 29, 2020
Nighthawk AX8 Orange Power LED
My Nighthawk AX8 is one month out of warranty, and it seems like it may have self-updated and bricked itself over night (or had some other issue rendering it unusable). I went to bed with everything working normally, didn't perform any updates or change any router settings.
This morning, I woke up and the power LED is orange, the WIFI light is white, but I'm unable to see either the 2.4 GHz or 5 GHz networks, and wired ethernet is not working/detected either. I have tried to power cycle, hard reset, and even left it off for a while and turned it back on. I'm using a backup router using the same ethernet cables and power outlet, so I know these aren't the issue. Is there any way to fix this issue or is my router now a very expensive paper weight? If the issue is a firmware issue, is there a way to manually install firmware that makes it work again?
Thank you.
