KySkies's avatar
KySkies
Nighthawk AX8 (RAX80) Coverage?
Hi,
Yesterday I upgraded my wi-fi router from Netgear AC1600 to Nighthawk AX8. The installation went well with no hickups and latest firmware version was installed.
My concern is the coverage area of the AX8 is no better at all then that from my older AC1600. I read a lot of reviews regarding the coverage area and the consensus was positive.
Before yesterday in order to get a signal to my back bedroom to my TV I was utilizing Netgear AC1200 Extender. To get a signal in the same room with Nighthawk AX8 I had to install the Extender again. This was not what I was expection at all!
The distance from where the router is installed to the bedroom TV is approximately 35'. What am I misissing here? One of the "wings" is pointed in the direction to the bedroom, if that makes a difference. Also, if it makes any difference at all, the router is in the family room that has 3 exterior brick walls. But the router is butted next to an interior sheetrock wall.
I have attached my house layout. It is single story ranch.
Any advise would be greatly appreciated.
  • plemans's avatar
    Are your interior walls brick? or the wall the router is against?
    Brick blocks wifi to an amazing extent. So does plaster lathe (many house with brick have plaster lathe interior walls).
    Something else to keep in mind. The new AX spec didn't increace antenna output power (because its set by the FCC) so  AX doesn't reach any futher than AC did. What it did do was allow a little more efficiency with a lower signal on AX devices. So AC devices aren't going to much extra distance (if any) and even AX devices will only get a little extra range. And even that isn't much.
    • KySkies's avatar
      KySkies
      Thanks for responce. My interior walls are not brick, only exterior walls. The router is against an interior wall as can see from the house layout.  If the routers "wings" are any indication as to how to point the beam (signal), then this means it's trying to penerate through 2 brick walls?
      • plemans's avatar
        the "wings' are omnidirectional. Meaning they broadcast in a circle. So it really shouldn't matter much how they're pointed.
        What are the interior walls made of?
