MolliKennedy
Jan 20, 2021Aspirant
Nighthawk AX8 RAX80 Need help using the 2.4ghz frequency for arlo security cameras
I've just purchased the arlo 3-camera wireless home security cameras and I am stuck! The set up guide says that the cameras will only connect to a router's 2.4ghz frequency. My question is basicall...
- Jan 20, 2021
Many of the arlo's need a hub to connect to.
And arlo isn't with netgear anymore. They're their own company.
Jan 20, 2021Guru - Experienced User
MolliKennedy
Thanks for the quick reply. However, I think I may not have explained my issue properly. I'm not sure I can even explain it any different.
- plemansJan 21, 2021Guru - Experienced User
What arlo camera's do you have?
Many of them connect back to an Arlo hub. That'd be setup using the hub.
You wouldn't find support on Netgear for an arlo issue.
And if its one of the couple that connect to wifi, then we can help with the netgear side of it.
