Rasmus0419's avatar
Rasmus0419
Initiate
Dec 30, 2019
Nighthawk AX8 unable o detect ethernet cable
Hi! Just got my new RAX80 today, and while setting it up it told me it couldn't fin the ethernet cable(in the app). I have tried restarting and resetting both the new nighthawk and the modem(another router from inteno) but it hasn't solved the problem. My old router works perfectly fine so the cables are fine. Any ideas of how to solve this?
  • Just got it to work in some how! Thanks for your help though! :)
  • What actual modem is it? A model number helps. many times you get issues during setup if its a modem router combo device which is why we ask.
    What firmware is on the router?
    • Rasmus0419's avatar
      Rasmus0419
      Initiate
