Insight-Music's avatar
Aug 31, 2020
Nighthawk AX8 voltage ?
Hello, does anybody know which voltage this router is support ? Can't find an official info about that (((( I'm asking because I have R7000 which I've bought in US and it works great in 220v with US to Euro plug adapter, without any converters. Will AX8 work like my R7000 in the same way ?
Thanks
1 Reply
  • plemans's avatar
    The RAX80 is labeled 110v-120v with an output of 19v 3.16amp.
    I know the orbis didn't say there were compabile with 220v but many were able to use them as such. I'm not sure if the RAX80 could be compatible with both 110v and 220v.  I'd be hesitant to try
