cas434
Apr 17, 2019Aspirant
NightHawk AX8 won't detect cables
Hello All,
I just purchased a brand new NightHawk AX8 router and during setup, it continues to tell me it cannot detect cables when I plug the ethernet cable into the route from my modem. So I ...
cas434
May 02, 2019Aspirant
I apologize for the delay. I am getting that message from the Nighthawk setup app. I did, in fact, unplug and remove the modem battery for a significant amount of time to try and reset it.
The modem is a Socket fiber modem that is hardwired into my home. I only have the ability to unplug it from the power source and remove the backup battery. There is a single Ethernet connection that you plug the chosen router into.
Christian_R
May 03, 2019NETGEAR Employee Retired
Hello cas434,
Have you gotten a chance to try setting up the unit using a laptop/computer?
~Christian
- cas434May 15, 2019AspirantNo. The material that came with the router only said the Nighthawk app was used for setup. It does not explain the setup process for a laptop.
- Christian_RMay 15, 2019NETGEAR Employee Retired
Hi cas434 - Please check out page 22 of the user manual : http://www.downloads.netgear.com/files/GDC/RAX80/RAX80_UM_EN.pdf
~Christian
- cas434May 15, 2019AspirantThank you very much. I will try that out tonight.
