cas434
Apr 17, 2019Aspirant
NightHawk AX8 won't detect cables
Hello All,
I just purchased a brand new NightHawk AX8 router and during setup, it continues to tell me it cannot detect cables when I plug the ethernet cable into the route from my modem. So I ...
nzjono
Sep 17, 2019Aspirant
I have the same exact problem with my new AX8 and cable internet. The AX8 just will not detect a working cable internet feed. How exactly did you fix your problem?
- michaelkenwardSep 17, 2019Guru - Experienced User
nzjono wrote:
I have the same exact problem ....Possibly, possibly not. There can be any number of causes of problems with routers.
Your message tells us not much. You have also joined in on an existing conversation – it started some six months ago – that may or may not have anything to do with your problems.
There is also a good chance that the official support team is busily monitoring new conversations and may miss your addition to this one.
If you do want help with your problem, check previous stuff that may be related then start your own discussion.
If you do decide to ask a question, you should provide more details and your own version of the information that the forum suggests that you provide. For example, as this is a router, it helps to know what modem you are using and the various things that you have tried to fix the problem.You can help people to help you by providing the information suggested in this forum's header:
Subject (Include model number and brief summary)
Model (Recommended - Helps the community give the best answers)
Body (Include additional detail including model version, firmware, OS and environment where relevant.)They are there for a good reason.
- saprimousSep 18, 2019TutorEnable QOS , on the router and reboot to ensure it stays
