Fanale12
Apr 01, 2020Follower
Nighthawk Ax80 got hacked?
Recently, I realized the internet got extremely slow, so I checked and show devices I don’t recognize on my network through the mobile app. I Tried locking those devices, still seem very slow. So I...
additude
Apr 03, 2020Virtuoso
Devices connected WiFi or Cable?
Don't just change your admin login password but equally as well change your SSID passwords for 5 and 2.4
Disable "Guest" logins...
Disable "Remote Login".....
Topology
Fanale12, you may wish to enable Access Control in the router, to allow only known devices to connect to your network – and, enable the access rule “Block all new devices from connecting.” While MAC authentication isn’t perfect, it should assist in preventing unknown/unauthorized devices from using the network.
