Retired_Member
May 02, 2021Nighthawk AX8/8-Stream AX6200 Tri-Band WiFi6 Router not connecting to Xerox Workcentre 3225 Printer
I recently purchased Netgear Nighthawk AX8/8-Stream AX6200 Tri-Band WiFi6 Router. All the devices are connecting fine except my Xerox Workcentre 3225 printer. Please note the printer is connecting ...
Christian_R
May 06, 2021NETGEAR Employee Retired
Hello ap333,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
