LisaW11114X
Sep 07, 2020Aspirant
Nighthawk AXA AX30004 WiFi router
Hi We have had our router for just over 1 year, of course the warranty has run out, but we need to keep turning it off to make it work. Then it will work for 24 hrs then stop working again and we h...
LisaW11114X
Hi
Firmware V1.0.3.80_1.0.1
It is connected to a telstra NBN Box
It does not turn off, all the lights are still on but there is no upload or download and it happens to both wired or wireless.
We have to turn it off all together to get it going again. You can just ask it to restart that does nothing.
Thanks
Lisa
Sep 08, 2020Guru - Experienced User
which telstra box? there's many different types. And some have their own integrated router which would put you in a double nat.
https://kb.netgear.com/30186/What-is-Double-NAT
it could also be the telstra box only asigning a lease time of a certain length and it not renewing like it should.
- LisaW11114XSep 08, 2020Aspirant
HI,
The NBN box dosen't have an internal router, it is just a standarded NBN box. The router has been working fine 18 months and just recently stopped working.
- plemansSep 08, 2020Guru - Experienced User
LisaW11114X wrote:HI,
The NBN box dosen't have an internal router, it is just a standarded NBN box. ----so what model is it?
https://kb.netgear.com/30439/What-is-an-NBN-network-and-is-my-NETGEAR-DSL-modem-router-compatible
- LisaW11114XSep 09, 2020Aspirant
Hi
Is the model number 1-240G-R this is about the only number I can really find.
But I just can't understand why we have had the same equipment for over 18 months now and this problem has only been happening in the last week. How can we have an issue with compatability now unless Netgear have changed something in the latest upgrade.
We do not have any subscriptions with our NBN that would cause this.
Thanks
Lisa
