Robstar
Nov 21, 2021Aspirant
Nighthawk AXE1100 losing internet
Hi, hope someone can help. I keep losing WiFi on my nighthawk axe1100 I have the most current FW loaded rebooted the modem and nighthawk. My internet is with Verizon Fios. I have there modem i...
Nov 21, 2021Guru - Experienced User
what actual router do you have? Nothing you put is the model number.
What firmware are you on? not the "latest"
What ont from verizon is it connected to?
Does it only happen to wireless devices? Wired are fine
- RobstarNov 21, 2021Aspirant
Nighthawk AXE1100 6E
the only device connect to the Verizon g1100 is the nighthawk router.
hardware Raxe500
firmwear is 1.0.8.70
- plemansNov 21, 2021Guru - Experienced User
If you leave the G1100 in router mode (disable its wifi) and put the RAXE in access point mode, does it function properly?
The rep put the version router in bridge mode.to be a pass through to my nighthawk
I rebooted the Verizon modem about 2 hours ago so far iits still online this is the longest it has stayed on.đ€
