Robstar
Nov 21, 2021Aspirant
Nighthawk AXE1100 losing internet
Hi, hope someone can help. I keep losing WiFi on my nighthawk axe1100 I have the most current FW loaded rebooted the modem and nighthawk. My internet is with Verizon Fios. I have there modem i...
Robstar
Nighthawk AXE1100 6E
the only device connect to the Verizon g1100 is the nighthawk router.
hardware Raxe500
firmwear is 1.0.8.70
Nov 21, 2021Guru - Experienced User
If you leave the G1100 in router mode (disable its wifi) and put the RAXE in access point mode, does it function properly?
- RobstarNov 21, 2021Aspirant
The rep put the version router in bridge mode.to be a pass through to my nighthawk
WiFi on version router has been disabled.
- plemansNov 21, 2021Guru - Experienced User
It wouldn't be the first "passthrough" mode that didn't function properly. Its one of the reasons I sometimes have people leave the ISP device in router mode (wifi disabled) and put the netgear in access point mode.
How do I put the ips router in WiFi mode and the nighthawk in access point
