AddisonGeek
Jul 08, 2026Aspirant
Nighthawk AXE7300 Tri-band WiFi 6E Router (RAXE290)
As I purchased the router and registered it in November 2022, how much longer is it going to be supported with firmware updates? Also, is there any possibility that open-source firmware will be allo...
Jul 08, 2026Guru - Experienced User
Can check here or EoL status:
https://www.netgear.com/about/eos/
Nothing lasts forever.
Keep checking NGs download site for updates.
Can always load 3rd party FW on NG routers for those parties that develop and support NG model routers. Will have to check with them to see what they support.
