AddisonGeek
Jul 08, 2026Aspirant
Nighthawk AXE7300 Tri-band WiFi 6E Router (RAXE290)
As I purchased the router and registered it in November 2022, how much longer is it going to be supported with firmware updates? Also, is there any possibility that open-source firmware will be allo...
schumaku
Jul 17, 2026Guru - Experienced User
FURRYe38 wrote:Can always load 3rd party FW on NG routers for those parties that develop and support NG model routers. Will have to check with them to see what they support.
There is currently no stable, third-party firmware (like OpenWrt, DD-WRT, or FreshTomato) available for the Netgear RAXE290. Because it is a high-end, tri-band Wi-Fi 6E router, developers have not created custom builds that fully support its specific Broadcom hardware and Wi-Fi drivers. Because you cannot flash open-source custom firmware, you must rely on official releases. The same applies to any similar Broadcom-powered models, too.
schumaku
Jul 22, 2026Guru - Experienced User
