buttons276
Feb 10, 2024Aspirant
nighthawk axe7800 no connection solid amber
I’m pulling my hair. I have a fiber optic internet connection with no modem. Current router is a linksys router that is working ok but I was having some slower than expected speeds and bought the nigh...
buttons276
Feb 11, 2024Aspirant
No I haven’t tried that. What kind of settings should I be expecting to change
michaelkenward
Feb 11, 2024Guru - Experienced User
Your ISP should have a list of settings that should go into the Internet settings.
Things like the login details.
One way to look for these would be to find the relevant settings in your linksys router. Note these down and put them into your Netgear router.
You didn't say what that router was, but you might find it useful to forage around in the manual.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. There will a section there for Internet settings and how to set up the router.
If you have the RAXE300 try this bit:
Manually set up the Internet connection
