bbwoods's avatar
bbwoods
Follower
Jul 22, 2021
NIghthawk C7000v2 Changed IP address, can no longer log in to router
I had to change the IP address of the router because of conflicting addresses in this house. (Other tenants are using a different [bad] internet provider with a router with the same IP address of 192.168.0.1) I changed it to 192.168.7.1 but after I did that and the router rebooted, I can no longer log in to the router using Netgear Genie or http://www.routerlogin.net or http://www.routerlogin.com or just typing in the IP address in a browser.
What can I do?
TIA
Brad
1 Reply
  • > Model: C7000|Nighthawk - AC1900 WiFi Cable Modem Router
       C7000[v1] or C7000v2?  Look for "Model" on the product label.
    > addresses in this house. [...]
       Eh?  "had to"?  Why, exactly?
       What, exactly, do you think is "conflicting" with what, exactly?
    Hint: There's no fundamental limit to how many routers "in this house"
    can use the same IP address, so long as you don't connect them to each
    other.  And if you do connect them to each other, then simply changing
    an IP address on one of them won't solve all the problems which you will
    have created.
    > [...] (Other tenants are using a different [bad] internet provider
       Which ISP is the bad one, and which is the good one?  And why does
    what "Other tenants" do affect you?
    > What can I do?
       Start again.  Reset the C7000[vX].  Describe what you're trying to
    do, and why.  Then, if you're experiencing some problem or other,
    describe that problem, rather than launching into some scheme to
    implement some "solution" ("changed it to 192.168.7.1"), which may have
    little or nothing to do with your actual problem.
    > [...] I changed it to 192.168.7.1 but after I did that and the router
    > rebooted, I can no longer [...]
       If you change the LAN IP address of your router to use a different
    subnet, then you might want to restart your client devices, too, so that
    they'll be sure to get new/compatible IP addresses, too.
       But if you have multiple routers (DHCP servers), using different
    subnets, sharing the same cables, then you can expect a bunch of
    problems because any client device will be broadcasting its DHCP
    requests to multiple DHCP servers, and taking the first response it
    gets.  Which could come from any of the routers (DHCP servers).
    > [...] I can no longer log in to the router [...]
       As usual, showing actual actions (commands) with their actual results
    (error messages, LED indicators, ...) can be more helpful than vague
    descriptions or interpretations.
       If you want to try to puzzle out what's going wrong now, then you
    might want to look at everyone's IP address, and see what makes sense
    and what doesn't.  But I suspect that when you stop connecting multiple
    routers together, all those problems will disappear, so careful analysis
    of the current mess might be of little long-term value.
