thehomez
Nov 18, 2021Aspirant
Nighthawk CAX30 no bridge mode?
Hi all, just got a Nighthawk CAX30 and I want to run it as a modem and router only. I have a Unifi WiFi system plugged into the router and therefore need to put it in bridge mode. I have searched for...
thehomez
Thanks so much for the help. The unifis are all just WAPs.
I can't seem to find the darn bridge mode. Good news is that I found the Cloud Key Controller! It was on a different subnet as my previous Netgear router used a different subnet.
And that's a great point about the switch. Much appreciated!
Do I even need to use bridge mode with my setup?
Razor512
Nov 18, 2021Prodigy
If you are only using the APs with the cloud key, then bridge mode will not be what you need, as unless you have some other router, bridge mode will leave you with no router at all Unless you are using a UDM that had both the cloud key and router in one.
