SanaNe
Jul 05, 2020Tutor
NightHawk connection issues with Xbox and printers
System: RAX80; Nighthawk is the single router and only connection to the modem; all devices are connected to Nighthawk only Modem: BGW210-700 (AT&T DSL -- yeah, sucks, but the only decent option whe...
- Jul 06, 2020
Modem: BGW210-700 (AT&T DSL -- yeah, sucks, but the only decent option where I live)
That looks supisciously like a modem router.
Two routers on your network can cause headaches, including those you list. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
Unless you have specific reasons for using two routers – to create two separate networks for example – it is often easier to use just one router and then to set up the second router as a wifi access point. Netgear advises this, as does just about every site you will visit.
It may be possible to put the modem/router into modem only (bridge) mode and then to use the second device as the router.There may be ways to get the modem/router to cooperate. Sometimes it is easier to put the second router into AP mode. But that has its own drawbacks:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
rinthos
Jul 05, 2020Luminary
Not sure what firmware version you are using and if you did a factory reset after upgrading (I know, shouldn't have to..but welcome to Netgear)...
A few questions though..if you turn off Device Access Control / Turn off the Allow List feature, does everything work as expected?
My guess..when your Printers go into 'sleep mode', the router cannot identify them and thus they get booted. Perhaps similar for the xBox? If you can try out the above suggestion and see if that feature is the culprit?
- SanaNeJul 05, 2020Tutor
Thanks! Firmware version is V1.0.3.88_1.0.41.
Just to make sure I'm taking the right action, do you mean factory resetting the RAX80 router or the other device (xbox / printer)? It seems I'd lose the new firmware if I go back to original settings. So, please let me know.
For the access control on/off swtiching, I had not seen any issue, but will try again and report back here.
