deltavee
Sep 10, 2020Aspirant
Nighthawk doesn't set up
My new RAX50 router won't set up. Using my iPhone Nighthawk app, I followed the directions but the steps won't progress past "router not found" even though my iPhone shows that it's connected to the ...
Christian_R
Sep 17, 2020NETGEAR Employee Retired
Hello deltavee,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
http://www.netgear.com/support/contact.aspx
Christian
brucecy92
Sep 22, 2020Aspirant
Thanks for sharing
