TKTran102
Jun 19, 2020Initiate
NightHawk fw upgraded to v1.0.3.80_1.0.1, 802.11n device connects OK but shows No Internet
RAX35 Nighthawk underwent firmware upgrade successfully to v1.0.3.80_1.0.1, afterward I enabled the new Smart Connect option, all Win10 wireless devices restored connectivity OK and were distributed ...
Jun 19, 2020Guru - Experienced User
Did you try forgetting the network and then reconnecting with that device?
- TKTran102Jun 19, 2020Initiate
Oh yah... several times to all wireless profiles and start with clean sheet... same results... logs show "[WLAN access rejected: incorrect security] from MAC address 00:26:82:65:65:1f, Fri,Jun 19,2020 14:05:07", so am thinking latest firmware probably updated minimum encryption key strength or algorithm... WLAN driver from Microsoft is dated 2015 and vendor name is an obscure Ralink not heard for a long time... might have to roll back firmware, but now trying to deselect AX feature to see if it'll make a difference.
