TKTran102
Jun 19, 2020Initiate
NightHawk fw upgraded to v1.0.3.80_1.0.1, 802.11n device connects OK but shows No Internet
RAX35 Nighthawk underwent firmware upgrade successfully to v1.0.3.80_1.0.1, afterward I enabled the new Smart Connect option, all Win10 wireless devices restored connectivity OK and were distributed ...
Jun 19, 2020Guru - Experienced User
Did you try forgetting the network and then reconnecting with that device?
TKTran102
Oh yah... several times to all wireless profiles and start with clean sheet... same results... logs show "[WLAN access rejected: incorrect security] from MAC address 00:26:82:65:65:1f, Fri,Jun 19,2020 14:05:07", so am thinking latest firmware probably updated minimum encryption key strength or algorithm... WLAN driver from Microsoft is dated 2015 and vendor name is an obscure Ralink not heard for a long time... might have to roll back firmware, but now trying to deselect AX feature to see if it'll make a difference.
