Version8
Dec 30, 2019Follower
Nighthawk iOS app issue
Set up was seamless, I was able to log into the iOS app, it after restarting the router, it keeps saying make sure my router is in the same WI-FI, which it is, my router is working properly and has multiple devices connected. But can’t connect to the nighthawk app via iOS. Please assist.
1 Reply
- desgrisonsAspirant
Had the same issues and had to delete the app, clear all network setting and then I was able to get a persistent signal. The app, in my opionion is not only underwhelming but also not designed for IOS. Thw hub works fine on Mac OS, IOS and windows if you stay away from their apps!!
