DANMAY1776
Aug 11, 2021Follower
Nighthawk LAX20 router as WiFi gateway ?
Hi, I am looking for a solution that will allow me to set up a local WiFi network using either an existing Ethernet or WiFi network as access to the internet, along with a possible cellular backup. ...
- Aug 11, 2021
For a router to connect to a wireless and use it as a WAN requires WISP mode.
The LAX20 doesn't have that.
the only netgear device that I know of that does is the PR2000 which is a very old travel router from netgear.
Not what I'd recommend and it doesn't support LTE/Sim.
Aug 11, 2021Guru - Experienced User
