Faceplant
Nov 13, 2021Tutor
Nighthawk mesh compatible with Nighthawk cable modem?
I bought a AX1800 mesh router with two extenders, but decided to replace my cable modem and router with an AX2700. Befoe I return the mesh system, I wanted to find out if the extenders might work wit...
- Nov 14, 2021
Wanted to also add, if I were using a CAX30 with something like the MK63, I would leave the router functions enabled in the CAX30, and set the MK63 to AP mode. I would then set all of the devices to use the same SSID and password.
The mesh product will have the full set of roaming assists between its satellites, while the CAX30 will rely on 802.11k and some client directed roaming functions which while a little slower to make a switch, will still work reliably.
Nov 14, 2021Guru - Experienced User
a couple things.
1. ax1800 and ax2700 are speeds not models. So we're not sure exactly what you have.
2. there are mesh systems that have cable capabilities like the CBK750. Potentially you could return both and still have a mesh system and a cable modem.
Faceplant
Nov 14, 2021Tutor
As for the CBK750. That does look nice, but I think it would end up costing more overall. That said, it would be a much cleaner (and I assume better in other ways) solution.
Does the CBK750 have updated firmeare over the CAX30? I'm really not impressed with the firmware on the CAX30. I just went though a complete re-configuration this morning due to not being able to edit or delete port forward settings, which, from what I could deduce, seems to be a common solution to that problem.
- plemansNov 14, 2021Guru - Experienced User
Its roughly the same interface. There tends to be very similar interfaces across product lines.
You could always use the CAX30 and connect the MK system to it with the MK in access point mode.
It'd be a cheaper option for you.
