Popnfresh
Mar 06, 2021Follower
Nighthawk Mesh extra satellite cost
At the end of last year I purchased the 2 pack mesh system for 170ish dollars. It's been amazing on the upper level where all tvs and devices test anywhere between 460 mbps to 550 mbps. However whe...
Mar 08, 2021Guru - Experienced User
It is a bit sad how much extra you pay for just buying a satellite versus buying the whole system with the extra satellites.
I don't have a good option for you to get extra satellites at a cheaper price. Maybe buying a the satellite system you want and selling your current, but the loss of value by selling a used system probably will ofset the $ you save buy buying the whole system.
And that system isn't cross compatible with orbi to open up those systems for usage.
